{{ $t('SketchUp Download') }}
{{ $t('The SketchUp SDK includes the SketchUp C API, LayOut C API, the SketchUp Importer/Exporter Interface, full documentation, example projects, as well as the deprecated SDK. It is available for Mac and for Windows.') }}
SketchUp C API
The SketchUp C API is an interface for reading and writing data to and from SketchUp models. This API interacts directly with SketchUp files (.skp). It can create new ones as well as read or modify existing ones.
Included in the SketchUp C API is the SketchUp Importer/Exporter Interface. This allows you to create native SketchUp importer and exporter modules that are available directly within SketchUp as an import or export option.
LayOut C API
The LayOut C API is an interface for reading and writing data to and from LayOut documents (.layout files). It can create new documents as well as read or modify existing documents.
{{ $t('Previous Versions') }}
{{ SDK_SKETCHUP_BUILDS.PRO_2023_1 }}:
{{ SDK_PACKAGES.WIN_2023_1.compatibility }}
{{ SDK_PACKAGES.MAC_2023_1.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2023 }}:
{{ SDK_PACKAGES.WIN_2023.compatibility }}
{{ SDK_PACKAGES.MAC_2023.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2022 }}:
{{ SDK_PACKAGES.WIN_2022.compatibility }}
{{ SDK_PACKAGES.MAC_2022.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2021_1 }}:
{{ SDK_PACKAGES.WIN_2021_1.compatibility }}
{{ SDK_PACKAGES.MAC_2021_1.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2021 }}:
{{ SDK_PACKAGES.WIN_2021.compatibility }}
{{ SDK_PACKAGES.MAC_2021.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2020_2 }}:
{{ SDK_PACKAGES.WIN_2020_2.compatibility }}
{{ SDK_PACKAGES.MAC_2020_2.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2020_1 }}:
{{ SDK_PACKAGES.WIN_2020_1.compatibility }}
{{ SDK_PACKAGES.MAC_2020_1.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2020 }}:
{{ SDK_PACKAGES.WIN_2020.compatibility }}
{{ SDK_PACKAGES.MAC_2020.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2019 }}:
{{ SDK_PACKAGES.WIN_2019.compatibility }}
{{ SDK_PACKAGES.MAC_2019.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2018_1 }}:
{{ SDK_PACKAGES.WIN_2018.compatibility }}
{{ SDK_PACKAGES.MAC_2018_1.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2018 }}:
{{ SDK_PACKAGES.MAC_2018.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2017 }}:
{{ SDK_PACKAGES.WIN_2017.compatibility }}
{{ SDK_PACKAGES.MAC_2017.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2016 }}:
{{ SDK_PACKAGES.WIN_2016_64BIT.compatibility }}
{{ SDK_PACKAGES.WIN_2016_32BIT.compatibility }}
{{ SDK_PACKAGES.MAC_2016.compatibility }}
{{ SDK_SKETCHUP_BUILDS.PRO_2015 }}:
{{ SDK_PACKAGES.WIN_2015_64BIT.compatibility }}
{{ SDK_PACKAGES.WIN_2015_32BIT.compatibility }}
{{ SDK_PACKAGES.MAC_2015.compatibility }}
{{ $t('Apply to be a developer')}} {{ $t(/** Previous text is Apply to be a developer */ 'to access previous versions.') }}
{{ $t('Sign in to access previous versions.') }}
